    Need help withTranspose column to row
    2 Posts 2 Posters 3.1k Views 1 Watching
    • Ángela RojasÁ Offline
      Ángela Rojas
      I have this:
      Wavelength LFH00300002.asd
      350 0.34586981
      351 0.34210269
      352 0.35421594
      353 0.34231914
      Wavelength LFH00300003.asd
      350 0.34586981
      351 0.34210269
      352 0.35421594
      and i need this:
      LFH00300002.asd 0.34586981 0.34210269 0.35421594 0.34231914
      LFH00300003.asd 0.34586981 0.34210269 0.35421594
      Can someone help me with this? Thank you.
        Hello, @ángela-rojas,
        Not very difficult with a regular expression, indeed !
        Assuming that :
        • The word Wavelength, with that exact case, begins a line and is followed by, at least, one space character
        • The different numbers, beginning the following lines, are followed by a single space character
        Just follow the few steps, below :
        • Move back to the very beginning of your file ( Ctrl + Origin )
        • Type (?-i)^Wavelength +|\R\d+ , in the Find what: box
        • Leave the Replace with: box EMPTY
        Et voilà !
        Notes :
        • The regex search looks, either, for :
          • The string Wavelength, with that exact case, followed by, at least, one space character ( + )
          • Some End of Line characters (\R ), immediately followed by, at least, one digit ( \d+ )
        • Whatever the case found, the overall match is deleted, due to the empty replacement regex
        Best Regards
        P.S. :
        • In case the numbers, beginning the line, are followed by several space characters, prefer the regex S/R, below :
        SEARCH (?-i)^Wavelength +|\R(\d+) +
        REPLACE ?1\x20
        • If the search must not be sensitive to case, just change the (?-i) part by the (?i) syntax
