    Auto-Indent not working
    6 Posts 4 Posters 3.8k Views 3 Watching
    • Rahul Kr SinghR Offline
      Rahul Kr Singh
      Auto-Indent Enable but not working what i do?
        Rahul Kr Singh
        pls anyone help
          Claudia Frank @Rahul Kr Singh
          @Rahul-Kr-Singh
          maybe you’re expecting something which is not the case.
          Afaik you have to set the first indentation and npp does this for the next lines based
          on the indentation from the previous line.
          • Stephanie OngS Offline
            Stephanie Ong
            Same here.
            It use to work but stopped and returns to zero since yesterday.
            I have to tab each line to where I want to start typing in both html and php.
              Stephanie Ong
              Same here.
              Had to install a portable version to fix (don’t have admin privileges on the computer that notepad++ broke so couldn’t tell you if a re-install would fix the problem
              • Omar CantoniO Offline
                Omar Cantoni
                I’ve found with v7.6 (32 bit) it does not work having loaded the “DoxyIt” plugin.
