    write in column mode add spaces for indention, instead of tabs
    3 Posts 2 Posters 3.7k Views 2 Watching
    • M Offline
      MaDill
      In my files I use tabs to indent. When I use column mode and write something the it add spaces at the beginning of the blank line and no tabs. Can this be setup somewhere or is there a workaround? I setup tab=4 and replace by space is not checked.
      Example
      A
      	B
      		C
      		X
      	Y
      Z
      Start with the column mode there:
      A
      	|B
      	|	C
      	|	X
      	|Y
      Z
      and write something
      A
      	bla|B
      	bla|	C
      	bla|
      	bla|	X
      	bla|Y
      Z
      Then in the line, which was blank before it is now <space><space><space><space>bla. Expected is <tab>bla.
      • dailD Offline
        dail
        Hi @MaDill
        I actually submitted a patch to Scintilla a little while back to fix this problem and it was merged into v3.6.7 (released Sept. 2016) of Scintilla. However Notepad++ is still on a much older version of Scintilla, so currently there is no work around that I know of.
        • M Offline
          MaDill
          Then let’s hope that N++ update Scintilla some day…
