    Problem editing using remote VNC connection
    2 Posts 1 Posters 1.5k Views 1 Watching
    • Gary MaddoxG Offline
      Gary Maddox
      I connect from home using Kaseya and a VNC connection. Control keys do not work in Notepad++. They work with ordinary Notepad but not Notepad++. I am used to ctrl-D to duplicate a line, ctrl-S to save, etc…
      I really need to figure this out so I can be productive and less frustrated.
      Does anyone have any idea how to remedy this problem???
      Thanks in advance.
      Gary
        Gary Maddox
        In reply to my own problem: I just installed v.7.4.2 and it seems to be working better.
        I noticed several views to this topic. Unless I report back with something negative, this could be solved.
        G.
