need help opening dat files
when try to edit dat files with notepad++ all i get is this thanks for the help in advance
SQAR」 tAZ$ツテVミs」/SC4DABDAP ツ・5DA|ムO・I-Sィウ、dSミ碯5・CAl^'eラ!SvロFA!メノウ]讒w\AネO・タ5S|y5・&5ン・A,
&e・vミャ\・,1^・>cAebリFェェ~ミh・>・2・・S・ア、ー珖ミ・_#H・タ&eソサSS0レFetkミ・5・A3O・VkS イ、4xミIW4エ・A3&e\ーvS・レFB跼3A・O・NwSタ4・ケ・[」4-゙A茴’e
ミdク]d・ Z]跫・A@ ロFmRミ
x7W7)ムsSE・、*チ4ミVフ_ケ。澗%ezンHS鞁Fエ2ミ昉5・AmュO・)JS6サア、ゥコ=ミ・)キ)A[マ’e
DYSネ釡FCrキF_跋・A憬M・澣SB7リ7モ|チA;・eIエンミサレ)Na_訶7ノAR2ルF莅ロミ
m5、MW5サ譽Sゥヲア、オルミコ棒3仡・et・S糊ロFョ柁ミホフ4ANヤN・5ソSFPイ、゚ツミ4硝ミA
・eクS勞ロFスィW’蘊踴瞠A朧・垓S碁5/ヨ・アレA&eイw\ガfoム_・・A&ほF」f4・heM4N鬼ロイ、琿ネ!\s,jハ%e瞹Т籐F;エミ~.4 褜6N・・Vー、$s・ュ6、韶Aオl'eロォS&DロF鎚n]3_贊顴⑨M㊨oヾJ|5co5oA艢&eK賻d禄リZr象^賈ニ畏FIO菻T・・q7r 欖8=イ、楼簟+ \QvLア%e兊儡゚叨F7耙カェ526イO㈲ス儡ゥ.ウ、・隯烋5c=Aィ;$es鱒S;リF:w|ワウ]・ヨ②ネO③鏨K・・)・1!窟=ェ'eアn斷スイ]">cス]觴L輸*飼Fロrσカ4ク・4lg続、ラミt。_D&
・erロネS槧リFィミチX4#「AA@N・ーハSエ豌、セミオ6t皰A・eZvニS・ルF)(テフ]詢ョAキO・GニS孔7ケ(ラ&7・ッAラ・e玄ミW・・.Nシ]譟LェA・Fュクミo・・・5・JオワS]ワア、オソ「ミN・&7・eソ5レS↑ルFe劬ミキ&4・教A7>N⑲ヤロS狃ア、愷。ミゥ・z+スA・%e・メS"ルFヲBツラ]譫C@ロャO・&Rテ=4xユ竸4カ畚@陲’eミ・ムhコ]C聢IW\觜、[@ レFリ」vム髜4 ・ヲ#4 -
What were you expecting to see in a text editor when opening this file?
.datfiles are generally data, specific to whatever application generated them. Often, they are binary – and it obviously looks binary based on your paste.If you want to be able to edit some underlying textual data, you will have to determine what application created the
.datfile, and find out whether there is a converter from that format to plaintext (it might be a converter, or an unzip-like utility, or a decompiler, or…). Once you have it in a text format, it will be easy to edit it with Notepad++. Once edited, you can use the same (or complementary) converter to get it back to the original format.Notepad++ isn’t some magic program that can “read any file format, convert it to text for editing, and convert it back to the original encoded format when saving”. It’s an excellent text editor, and with the associated scripting and assuming an appropriate converter, it would be possible to automate the process of convert-on-load, convert-on-save, but it’s not going to be able to take an arbitrary binary format and magically know how to decode/decompile it.
