    Notepad++ and wrong ANSII encoding
    4 Posts 3 Posters 5.9k Views 2 Watching
    • LuciferSam86L Offline
      LuciferSam86
      Hello everybody : I have the following C# code which converts an UTF8 W/O BOM into an Windows-1252 textfile:
              string inputstring = File.ReadAllText(@"c:\tmp\stringa.txt");
              var srcEncoding = Encoding.UTF8;
              var destEncoding = Encoding.GetEncoding(1252);
              var destBytes = Encoding.Convert(srcEncoding, destEncoding, srcEncoding.GetBytes(inputstring ));
              var destString = destEncoding.GetString(destBytes);
              File.WriteAllBytes(@"c:\tmp\output0.txt", destBytes);
              return destEncoding.ToString();
      When I open the output0 file into Windows notepad I can see the italian accent letters right, but if I open Notepad++ the ANSI codepage is Windows-1251 and not Windows-1252.
      The original file is an UTF-8 file created with Notepad++ , and Windows is configured with the Italian codepage (1252) correctly.
        Claudia Frank @LuciferSam86
        @LuciferSam86
        may I ask which npp version (debug-info from ? menu) and windows version you use?
        How did you configure Settings->Preferences->New Document->Encoding?
          LuciferSam86
          Hello, here the debug info:
          Notepad++ v7.5 (32-bit)
          Build time : Aug 15 2017 - 23:02:57
          OS : Windows 10 (64-bit)
          Plugins : mimeTools.dll NppConverter.dll NppExport.dll
          The O/S is Windows 10 Professional 64 bit Italian
          The encoding of “New Document” is:
          • UTF-8 and is enabled the sub-option “Apply to opened ANSI files”
          Thank you
            Hi @luciferqam86, @claudia-frank and All,
            Is it better if you uncheck the Autodetect character encoding option, in Settings - Preferences… - MISC ?
            Sometimes this auto-detection causes some problems, instead of avoiding them :-D
