    PythonScript not displaying errors in console
    console dialogerrorpythonscript
    10 Posts 3 Posters 6.7k Views 3 Watching
    • William WinderW Offline
      William Winder
      When my python script does not work, I get no message in the open console window. My startup.py looks ok (see below).
      I also wrote a script that had only print(“error”) and nothing happens when I run it.
      Other scripts (without stdout or errors) do run correctly. Just can’t seem to get anything to the console.
      Any suggestions?
      # The lines up to and including sys.stderr should always come first
      # Then any errors that occur later get reported to the console
      # If you'd prefer to report errors to a file, you can do that instead here.
      import sys
      from Npp import *
      # Set the stderr to the normal console as early as possible, in case of early errors
      sys.stderr = console
      # Define a class for writing to the console in red
      class ConsoleError:
      	def __init__(self):
      		global console
      		self._console = console;
      	def write(self, text):
      		self._console.writeError(text);
      # Set the stderr to write errors in red
      sys.stderr = ConsoleError()
      # This imports the "normal" functions, including "help"
      import site
      # This sets the stdout to be the currently active document, so print "hello world",
      # will insert "hello world" at the current cursor position of the current document
      sys.stdout = editor
        Claudia Frank @William Winder
        @William-Winder
        as long as
        sys.stdout = editor
        is set, print statement would be written to the active document.
        If you want to have it in the console, you would need to change it to
        sys.stdout = console
        or using a class similar to the ConsoleError.
        Concerning the errors, how do you call/run those scripts?
        William WinderW 1 Reply Last reply Reply Quote 1
          Scott Sumner
          I was going to point out that this SHOULD generate an error, because the Pythonscript plugin uses Python 2.7 and print("error") is Python 3 syntax. However, I tried it and it does not generate an error, and actually performs the print (irrespective of the destination of the output).
            Claudia Frank
            Hi Scott,
            I tried a quick search but could figure out which subversion of 2.7 introduced this feature.
            So both print syntaxes are allowed/correct.
              Claudia Frank @Scott Sumner
              Hi Scott,
              found it, print function has been introduced with version 2.6.
                Scott Sumner @Claudia Frank
                @Claudia-Frank
                Well… :
                Imgur
                In Python2 (which includes Pythonscript), print(...) calls the print builtin with a tuple argument (maybe tough to prove with a one-element tuple?). This is easy to see above with a 2-element tuple, above. :-D
                Of course, if you follow the advice of the docs you pointed to, and use from __future__ import print_function first, things are very different:
                Imgur
                So really, I was surprised by print("error") not producing a real Python error, but maybe I shouldn’t have been – it’s just printing a one-element tuple (I think).
                At the risk of being torn apart by Claudia the Python guru, that’s my analysis…and maybe this is really too far outside being Notepad++ related. :-D
                  @Scott-Sumner
                  hahahaha - obviously the guru didn’t understand what you did so who is the guru :-)
                  Yes, print function is only available when using import …
                  but no, I guess, the print statement doesn’t treat it as tuple but as str.
                  >>> type(("message"))
                  <type 'str'>
                  >>> type(("message",))
                  <type 'tuple'>
                  But your again write - not notepad++ related. :-)
                    William Winder @Claudia Frank
                    @Claudia-Frank Yes, it’s working now. i commented out everything concerning ConsoleError and set the stderr and stdout to console. Now everything seems to work properly. Not sure what the ConsoleError class does, or rather when it is triggered, but it was not sending errors to console.
                    I generally run the scripts by selecting the script through the PythonScript menu. That’s so I can have it work on an active editor text.
                      @William-Winder
                      the ConsoleError class is responsible for formatting the message differently as a normal message.
                      If the standard error pipe should be used, than python script uses the write method of this class,
                      which itself uses the writeError method if the console object. Which basically means, it writes
                      the message in red.
                      If the standard output pipe is used and sys.stdout is set to console, then python script uses the
                      console.write method which doesn’t do a special formatting of the output.
                      So it looks like the rest of the console window.
                      @Scott-Sumner,
                      it seems vacation was to long. You write posts that’s for sure but you are right about our discussion :-D
                      William WinderW 1 Reply Last reply Reply Quote 0
                        @Claudia-Frank I should do some experiments: when that class was not commented out, I got nothing in the console, black or red. It isn’t a problem now, but I’m a bit curious. (Thanks for the tips.)
