    split view or dual instance
    3 Posts 3 Posters 2.6k Views 3 Watching
    • Jeffery P KrauseJ Offline
      Jeffery P Krause
      Is there a way to have two instances of notepad++ running or maybe split the screen to view 2 or 3 files simultaneously?
      Claudia FrankC S 2 Replies Last reply Reply Quote 0
        Claudia Frank @Jeffery P Krause
        @Jeffery-P-Krause
        npp supports two views
        View->Move/Clone Current Document
        and several instances if multi instance is set
        Settings->Preferences->Multi-Instance
          Scott Sumner @Jeffery P Krause
          @Jeffery-P-Krause
          Even if Settings menu -> Preferences -> Multi-Instance is set to Default (mono-instance), right-clicking on an edit-window tab offers Move to New Instance and Open in New Instance choices that work.
          If this (or ANY posting on the Notepad++ Community site) is useful, don’t reply with a “thanks”, simply up-vote ( click the ^ in the ^ 0 v area on the right ).
