    Problem with the search and replace function
    3 Posts 2 Posters 1.5k Views 2 Watching
    • Wolf KürschnerW Offline
      Wolf Kürschner
      I just have installed Notepad++ and it works well for some search and replace work. I have a folder with hundreds of sub folders, with about 4000 html files. What I want to do is: delete all of the html in the files except for a small part (four lines - the files are 40kByte!).
      If I search for e.g. “<head>” and replace it with “” (nothing), this works well. But I’d like to delete larger parts of the files, e.g. the whole head section, that is: all between “<head>” and “</head>”. I tried it with <head>(.*?)</head> and a lot of other expressions found here in the forum, but none of them works?? What am I doing wrong??
      Truly yours,
      Wolf
      • Scott SumnerS Offline
        Scott Sumner @Wolf Kürschner
        @Wolf-Kürschner
        It seems like you might need to span lines with your search? Maybe try:
        Find-what zone: (?s)<head>.*?</head>
        The (?s) part will allow the . part to match line-ending characters, thus allowing the matching to cross line boundaries.
          Wolf Kürschner
          YES!!
          Stupid me…
          Works well now!
          Thanks a lot!!
          :-) Wolf
          (By the way: Is there a help file somewhere? Beside foum and “Command LIne Arguments”?
