    File assosiactions do not work if Notepad++ is installed to another partition other than C:\
    3 Posts 2 Posters 1.5k Views
    • Stavros SkamagkisS
      Stavros Skamagkis
      Hello, until today I had version 6 installed to my C:\Program Files (x86) directory.
      Today I installed the latest version 7.5.3 to another partition of my drive, letter M:.
      I installed to directory M:\Program Files (x86). But after installation Notepad++ could not be assosiated with .txt files. I tried to use Windows 7 “Open With…” dialog but it did not work at all.
      But after I uninstalled the program from the M:\ partition and reinstalled it to C:\ partition, the file association worked again with .txt filles.
      I want to install Notepad++ to another partition, can anyone help?
      Thanks,
      Stavros.
      • Claudia FrankC
        Claudia Frank @Stavros Skamagkis
        @Stavros-Skamagkis
        did you try default programs applet (under control panel)?
          Stavros Skamagkis
          Yes, I tried the default programs applet but Notepad++ isn’t in the list of programs.
