    • Categories
    • Recent
    • Tags
    • Popular
    • Users
    Messed up my settings. Help.
    Help wanted · · · – – – · · ·
    • Don BonnenfantD
      Don Bonnenfant
      I have messed up my main file page look. How do I get back to the orginal settings. When I click on a line it go black so it is not readable.
      • Claudia FrankC
        Claudia Frank @Don Bonnenfant
        @Don-Bonnenfant
        depending on your usage and configuration you need to do different actions.
        If you use a customized theme/style then you need to download a zipped npp version
        and extract the theme into your installation. If you use the the default theme/style then
        you can rename the file stylers.xml, which is either in your installation directory or under
        %APPDATA%, and then start npp. The file will be recreated with the default settings.
