    Big encoding problem with UTF-8 / UTF-8-BOM / ANSI / ISO-8859-1
    4 Posts 2 Posters 5.2k Views 2 Watching
    • Sybell LirwacoS Offline
      Sybell Lirwaco
      notepad++ v7.5.2 (32 bit)
      Win 7 Ultima
      I use notepad++ with WinSCP and have a huge problem with the encoding.
      HTML and PHP files are in HTML5 with <meta charset = “UTF-8”>.
      If I save the .htaccess in UFT-8-BOM, then HEAD will show on the command line for HTML and PHP files stored in UTF-8 or UTF-8-BOM: iso-8859-1.
      If I save the .htaccess in UTF-8, then HEAD shows no charset on the command line for HTML files and UTF-8 for PHP files. No matter if they are stored in UTF-8 or UTF-8-BOM.
      But if I close and reopen the .htaccess in UTF-8, it will open in ANSI !!!
      When I create a new file with WinSCP, it opens in ANSI. In the WinSCP settings the default encoding is UTF-8 and notepad++ is set to open a new document in UTF-8-BOM.
      Where is the problem here?
      • dailD Offline
        dail
        This is a known bug in v7.5.2 and v7.5.3 so I’d suggest you stick with v7.5.1 for the time being.
        Pull request to fix the issue is here https://github.com/notepad-plus-plus/notepad-plus-plus/pull/3992
          Sybell Lirwaco
          Many thanks for your very helpfull hint! It saves my work.
            Sybell Lirwaco
            Unfortunately the problem with 7.5.1 is not solved.
            npp.7.5.1.bin.minimalist.x64 opens files stored in UTF-8 containing characters from the Mathematical Alphanumeric Symbols Unicode block as ANSI.
            What I have just seen is that the term “ANSI” means different. Once the term ANSI means Windows-1252 (Menubar -> Encoding) and once means only ISO-8859-1 (Preferences -> New Document -> Encoding). Or there are problems because files stored in Windows-1252 are opened as ANSI, even if “Apply to opened ANSI file” is set.
