    Open as does not work anymore on 64bits
    1 Posts 1 Posters 958 Views 1 Watching
    • Rian83R Offline
      Rian83
      I’ve reinstalled my laptop in Win 64bits, so I tried to install Npp 64 bits, and it works but there is not enough plugin. And when I right click on a file on Windows Explorer, I can add Npp to the list of default program :
      Procedure :
      Right click on a file .txt for example
      Choose open with > Choose default programm
      Then I browse to get my notepad++.exe
      And that it, Npp is added to the list.
      But I unistall the 64 bits version for install the Npp x86 (to get more plugin). But this procedure does not work anymore. When I do this, the npp.exe is not added to the list.
      This is the first time I saw that. I was thinking it’s Windows which handle that. I don’t know why it’s not working …
      I’ve used the File Association menu in Npp to achieve that since the standard procedure is buggy. I need to be Windows admin but I don’t have this privilege on every laptop.
      Are you aware of this bug ?
