    problem error file too big to be opened
    19 Posts 6 Posters 17.2k Views 3 Watching
    • Fun FunF Offline
      Fun Fun
      hey, please fix this problem
      thnak you
        Claudia Frank @Fun Fun
        @Fun-Fun
        which problem?
        The message “error file too big to be opened” is an useful information telling you exactly
        the reason why your file, under your current setup, cannot be opened.
        • Meta ChuhM Offline
          Meta Chuh moderator
          @Claudia-Frank @Fun-Fun probably wants a free memory upgrade sponsored by np++ or else he will thnak us ;-)
          Claudia FrankC Alan KilbornA 2 Replies Last reply Reply Quote 2
            Claudia Frank @Meta Chuh
            @Meta-Chuh
            probably :-D
            • Fun FunF Offline
              Fun Fun
              it’s the program that can not open the file, my pc is powerful
                @Fun-Fun
                my pc is powerful
                might be - but you need to explain what you are trying to achieve in more detail.
                Just stating that you got a message … isn’t really helpful.
                  Alan Kilborn @Meta Chuh
                  @Meta-Chuh
                  Better be careful with the use of “he”. Of course the little pictures to the left (of some) of our names don’t necessarily have to tell the truth. ;)
                  Maybe even Claudia is not what she appears to be… :-)
                    Claudia Frank @Alan Kilborn
                    Alan, who knows - you might be wrong or right - I guess we will never find out
                    unless you find some leaked nude pictures at some celebrities websites :-D
                    • Fun FunF Offline
                      Fun Fun
                      my message is very clear, and I am a man
                      .thank you
                        @Fun-Fun
                        sorry but it isn’t very clear because if, for example, you try to edit a 10GB file
                        you would immediately get a response that this won’t work and it is very unlikely
                        that there will be a solution in the near future.
                        BUT if you try to edit a 100MB file the answers would be different with some additional questions.
                        • Fun FunF Offline
                          Fun Fun
                          ok, you want some detail, my file size 3 GB
                            @Fun-Fun
                            sorry but scintilla has, afaik, a 2 GB limit.
                            But this doesn’t mean that you can open a 2 GB file as scintilla internally
                            needs to allocate more bytes depending which lexer is used and if folding is active
                            and …
                            In addition the limit happens also if you have multiple big files you want to open
                            and which might have a total of 2 GB.
                            • chcgC Offline
                              chcg
                              What about 64bit (https://notepad-plus-plus.org/repository/7.x/7.5.4/npp.7.5.4.Installer.x64.exe)? I guess @Fun-Fun you are using the 32bit version of N++.
                              • Frank OrellanaF Offline
                                Frank Orellana
                                3GB is a very big file, I’ve managed to open files that big in Notepad++ 64bits as @chcg says. But it might not be as fast as you would expect.
                                For files that big another editor might be useful (try VIM or something like that)
                                  Claudia Frank @chcg
                                  @chcg @Frank-Orellana
                                  You were able to load a 3 GB file with notepad x64 version?
                                  Afaik, there is this 2 GB internal scintilla limit how did you go around this?
                                  • Fun FunF Offline
                                    Fun Fun
                                    I used the 32-bit version and 64-bit version of N ++.
                                    the problem remains the same.
                                      Alan Kilborn @Fun Fun
                                      @Fun-Fun
                                      I don’t know that it is a “problem” to not be able to open a 3GB file in Notepad++…well, maybe except for you. Notepad++, as others have stated, doesn’t have opening files that large in its design criterion.
                                        Claudia Frank
                                        OK - I did a test and was able to open a file with 1,9 GB but not more (7.5.4 x64)
                                        So I think the 2 GB limit is still in place. (Must be as npp hasn’t updated scintilla recently anyway)
                                          Claudia Frank
                                          Did some further testing, pure ascii text file 2,146GB,
                                          with 1MB more I do get the limit error.
