    HELP! i can't go to settings
    settingserrorhelp
    2 Posts 2 Posters 1.5k Views 2 Watching
    • AvatziaA Offline
      Avatzia
      i changed the toolbox icons but i don’t like it so i want to change and there is no settings button, basically all the configurations buttons are gone. please i need help.
      • decodermanD Offline
        decoderman
        Is NPP in full screen mode?
        Key F11 switches between the standard and full screen mode.
        If you see the Menu Bar, go to Settings > Preferences.
        On the center panel in “General” in the Toolbar section uncheck either “Hide” or select one of the icons selections.
