    Is SciLexer.dll part of Boost Library? and Why adopted?
    2 Posts 2 Posters 1.2k Views 2 Watching
    • Bin WangB Offline
      Bin Wang
      Dear All,
      i am very new to c++. but i very much appreciate the concept of Notepad++ development — use pure Win32 API to keep the performance.
      my question are as below:
      1 doe notepad++ use Boost Library?
      2 the use of Boot library in notepad++ is for simplifying the GUI development ? if yes, can you give me some examples of GUI components referred in Boost by notepad++
      3 what is SciLexer.dll for?
      thanks in advance
      • Scott SumnerS Offline
        Scott Sumner @Bin Wang
        @Bin-Wang
        1. Yes
        2. No; Boost is used in Notepad++ for its regular expression engine, not any part of its GUI
        3. SciLexer.dll is the (modified) Scintilla project code that is the core of Notepad++'s editing abilities
