    Can i work with more than one Favorites.dat and more than one shortcuts.xml
    5 Posts 3 Posters 2.0k Views 3 Watching
    • Norbert QuastN Offline
      Norbert Quast
      Can i start Notepad++ with parameter
      for assign favorites.dat and/or shortcuts.xml
        Claudia Frank @Norbert Quast
        @Norbert-Quast
        Which command line arguments are available can be seen under ? menu.
        But you will find out that shortcuts.xml isn’t one of them.
        What you can do so is to create a batch file which
        copies your modified shortcuts.xml over the default one,
        which, of course, should be saved beforehand.
        Concerning favorites.dat, what should this file hold?
        Doesn’t seem to be a standard npp file.
        Norbert QuastN 1 Reply Last reply Reply Quote 1
          Scott Sumner
          Favorites.dat is used by the Explorer plugin…and Claudia’s proposed technique should work just fine for it as well.
            Norbert Quast @Claudia Frank
            @Claudia-Frank said:
            @Norbert-Quast
            Thank’s
              Norbert Quast @Scott Sumner
              Thank
