    FIX Protocol parser for Notepad++
    6 Posts 3 Posters 7.9k Views 2 Watching
    • Franck DenyF Offline
      Franck Deny
      I’m trying to develop a FIX Protocol parser for Notepad++.
      FIX protocol is a protocol a bit similar to ini code [code=value].
      This is documented on several websites (http://fixwiki.org/fixwiki/FIXwiki …)
      My resources are a js file containing all values per tag
      https://raw.githubusercontent.com/drewnoakes/fix-decoder/master/src/scripts/app/data.js
      Is there any way to use this file to parse the FIX ?
      Sorry, it’s my first NPP development without any IDE :'(
      Thanks a lot.
        Claudia Frank @Franck Deny
        @Franck-Deny
        it’s been a while since I had to use FIX and FAST but at that time, QuickFIX seemed to be
        a good and already stable parser.
          Franck Deny
          Thanks Nadia for this help :)
          May i ask you if you managed to use it and integrate with Notepad++ ?
            @Franck-Deny
            Hmmm, don’t know who Nadia is ;-)
            but I started using standalone exe together with NppExec to make it work
            but afterwards the python modul .
            What I did at that time was to decode fix messages based on a xml file containing
            the fix fields and sending fix messages for testing.
            I can see if I find some old scripts if you are interested but you have to be aware
            that I can’t say if they are still valid and that was the time as I started playing with
            python. I would probably rewrite them nowadays.
            Kartik ParasharK 1 Reply Last reply Reply Quote 0
            • Kartik ParasharK Offline
              Kartik Parashar @Claudia Frank
              @Claudia-Frank
              I am newbie and thank you so much for the link , i was finally able to get the new version of quickfix with the python files. If you were able to successfully implement the quickfix connection, can you please post a small snippet of code on how to connect via python to any fix based server. I am struggling to get examples on how to do it.
                Claudia Frank @Kartik Parashar
                @Kartik-Parashar
                what about using the current documentation? Do the python examples not help anymore?
                http://www.quickfixengine.org/quickfix/doc/html/application.html
                My testing scripts were based on this exampls and btw. there is no such thing as
                the one-and-only fix program which connects to any fix server because exchanges
                tend to implement their own number of messages and fields to met their requirement.
                You always have to adapt it a little bit. FIX just defines the protocol and mostly the
                workflow what needs to be done but you can expect that there is always a slight
                difference from exchange to exchange.
                Btw. there are also a lot of stackoverfow messages concerning quickfix and python.
                I would think you get a better chance to get your problem solved when asking there.
