    Where in Notepad++ is the guide for Bold, Italics, etc?
    7 Posts 4 Posters 135.0k Views 3 Watching
    • Libby Len TraubmanL Offline
      Libby Len Traubman
      Is there a table to show keys to create Bold, Underline, Italic, Alignment, etc?
      MAPJe71M 1 Reply Last reply Reply Quote 0
      • MAPJe71M Offline
        MAPJe71 @Libby Len Traubman
        @Libby-Len-Traubman there isn’t as it’s not supported by Notepad++.
        • chcgC Offline
          chcg
          see also http://www.nytimes.com/2009/04/23/technology/personaltech/23askk-002.html and n++ is just a text editor.
            Libby Len Traubman
            Thank you so much for these helpful replies.
            Is there a rather simple program you can help me discover that has this quality?
            Gratefully, Len
              Claudia Frank @Libby Len Traubman
              @Libby-Len-Traubman
              standard MS notepad or wordpad for example.
                Libby Len Traubman
                I meant to ask if there’s a simple Notepad+±like software that is designed to create Web pages, including a feature allowing Preview in a browser.
                  @Libby-Len-Traubman
                  so I assume your initial question about bold, italic was also related to html programming?
                  If so, yes you can use npp to create webpages but notepad++ doesn’t have any help file
                  how to create a webpage.
                  What you can do is to use web resources like https://www.w3schools.com/
                  and once you’ve written your code use run menu and one of the browser functions like
                  launch in firefox etc…
                  But, again, notepad++ does not provide all those browsers it just assumes
                  that you have, at least one, installed, and tries to start it with the current document open as parameter to the browser executable.
