    HELP: NP++ Portable does not save its settings!
    portablesettings
    3 Posts 2 Posters 1.7k Views
    • Enkidu0815E
      Enkidu0815
      • I am using Win7 in an enterprise environment.
      • I have downloaded latest version of NP++ from portableapps.com.
      • I installed it to desktop.
      When I open it by using Notepad++Portable.exe, change language (or any other setting), close NP++, reopen it again, language is English again.
      I have no idea why. What I checked so far:
      • Googled for same problem but could not find a solution
      • There is no %APPDATA%\Notepad++ directory
      • There is no %ProgramFiles% or "%ProgramFiles(x86)% directory
      • All dirs/files in NP+±Portable-Apps folder are writable
      • There is no registry entry refering to a NP++ installation
      • No \Notepad++Portable\Data\settings\config.xml is generated
      • Other portable apps have no issue writing their config
      I really have no idea why NP++Portable does not save its setting. But this behaviour is really annoying…
      Any hint/help is very welcome!
      Tnx,
      Enkidu
      • Claudia FrankC
        Claudia Frank @Enkidu0815
        @Enkidu0815
        sorry but portableapps is doing additional tasks like extracting, copying files
        etc… I assume you might get better help in their forum unless you find some
        users here which do use this package and have already investigated what
        portableapps does under the hood.
        Why not using just a zipped version from official download page?
        • Enkidu0815E
          Enkidu0815
          Oh… Tnx. I was not aware that it is so easy. :)
          I downloaded ZIP version and it is working as expected.
          Tnx!
