Problem validating XML
I’m trying to validate an XML and i get this error:
Following error occurred during schema resource at ‘MPEDDCidfBlkDirDeb.xsd’Any ideas?
thanks.
Using what n++ 7.5.4 with xml tools plugin 2.4.9.2?
32bit/64bit?
Syntax check is ok?
