    Python 3 and Python scripts plugin
    24 Posts 7 Posters 25.3k Views 4 Watching
    • Bill WinderB Offline
      Bill Winder @Vitaliy Dovgan
      @Vitaliy-Dovgan Thanks! Good work around. There must be somewhere direct access to an unsaved tab, because I can close npp with an unsaved tab and when I reopen, it is there. So the unsaved tab is actually saved somewhere. Curious!
        Scott Sumner @Bill Winder
        Yes, saved under a “Backup” folder by default. I just made 5 “new files” and they were created in this folder with the following names:
        new 1@2018-02-19_155611
        new 2@2018-02-19_155613
        new 3@2018-02-19_155613
        new 4@2018-02-19_155615
        new 5@2018-02-19_155618
        Bill WinderB 1 Reply Last reply Reply Quote 0
          Bill Winder @guy038
          @guy038 Very cool! I just chose fonts at random until things looked right. Useful description, which will serve elsewhere also – same issue in Jedit. (Though I use Jedit less and less - npp has everything I need and is very fast.)
            Bill Winder @Scott Sumner
            @Scott-Sumner and they are numbered! Perfect. Which essentially solves my problem.
            I hope! There is one further step. I will have to capture the name of the active tab and give it to NPPEXec.
            But that should be possible through the sci_sendmessage function (will look into that), since this is possible:
            sci_sendmsg SCI_GETSELECTIONSTART
            set local selStart = $(MSG_RESULT)
