    • Search
    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Search
    Prefix and suffix a text entry at start of every line
    Help wanted · · · – – – · · ·
    • Richard Avon
      Richard Avon last edited by
      Hello
      Enjoy Notepad++. Much appreciated.
      I’m stumped. Needing to change following, for egs.
      1 xxx zzz
      2 aaa ddd
      To
      (1) xxx zzz
      (2) aaa ddd
      Similarly same for last entry of every line.
      I have Googled to no avail.
      Really appreciate help thank you.
      Claudia Frank 1 Reply Last reply Reply Quote 1
      • Claudia Frank
        Claudia Frank @Richard Avon last edited by
        @Richard-Avon
        from your provided data I would assume that you are looking for
         find what:^\d
         replace with:\($0\)
        with regular expression checked.
        But it might be that the find what needs to be modified if two or more digits form a number,
        but I can’t say for sure as I don’t know how your data really looks like.
        Richard Avon 1 Reply Last reply Reply Quote 0
        • Richard Avon
          Richard Avon @Claudia Frank last edited by Richard Avon
          @Claudia-Frank
          Thanks Claudia
          I’ll try this when get back to office later today.
          My data is a bit more complex than shown above.
          Typically
          100 12°15’34" 12.562 o’stones
          101 35°38’56" 17.765 p&r fence
          102 84°40’10“ 25.456 bricks
          And so on in similar fashion
          The numbers (point numbers) at beginning of each line maybe any numeral from 1 to say 1000, and random.
          Regards
          • Claudia Frank
            Claudia Frank @Richard Avon last edited by Claudia Frank
            @Richard-Avon
            then replace “find with” with this one
             ^\d+
            ^ marks that it is the start of the line
            \d it must be a digit
            and the plus sign at the end tells that it must be at least 1 digit,
            without the plus sign it is looking for exactly one digit.
            Replace with is still the same.
            • Richard Avon
              @Claudia-Frank
              Many thanks Claudia. Brilliant.
              Thanks for taking the time to explain this.
              In much appreciation
              Regards
              Richard
