    Can we have Ctrl + Shift + R (Open Resource..) equivalent for Notepad++?
    3 Posts 2 Posters 2.9k Views 1 Watching
    • Aman S. AnejaA Offline
      Aman S. Aneja
      Generally, I open more than 50 to 60 files in Notepad++
      Sorting it alphabetically is not something I can use because the files are open in a certain flow and order.
      To scroll and find a specific file is a pain sometimes. Can we have a feature wherein we can have a popup text input or a search bar on the top right where we can type the name of the already open file and jump to that tab?
      Please consider!
      Thanks,
      Aman
        Hello, @aman-s-aneja, and All,
        There an excellent plugin , created by @young-developer, which does exactly what you wish to :-))
        Just read the README.md section at :
        https://github.com/young-developer/nppNavigateTo/
        Then, download the latest release v1.12.3 ( both in x32 or X64 versions ) from :
        https://github.com/young-developer/nppNavigateTo/releases
        Indeed, as Young-developer says, even with more than 50 files, simultaneously opened, you do NOT need, anymore, to have the Preferences > General > Tab Bar > multi-lines option set !
        Once, this plugin installed and N++ restarted :
        • Hit the Ctrl + , ( comma ) shortcut to launch it
        • Type in some chars, part of the filename, which you want to open in N++
        • Then double-click on the right one, from the short list which occurs
        Et voilĂ  !
        P.S. :
        Oh ! Seemingly, there a small bug with the latest v1.12.3 version ! It does not list the very first tab of current N++ session !
        I just tested the v1.12.2 version. Worked just fine, without any crash !
          Aman S. Aneja
          Hello @guy038,
          That is excellent. I tried your suggestion and it works perfectly.
          Thanks a ton!
          With your input, this post could be even better đź’—
