    how to move text to other location in notepad
    7 Posts 2 Posters 5.0k Views 1 Watching
    • Vuvanvui VuiV Offline
      Vuvanvui Vui
      Hi guy! I want to ow to move text to other location in notepad++ with replace or macro
      ex: i have some text:
      <p>Here’s to the crazy ones, the misfits, the rebels, the troublemakers, the round pegs in the square holes… note1 the ones who see things note2 differently </p>
      <fn=1>text aaaaaa</fn>
      <fn=2>text bbbbbb</fn>
      I want to replace or macro to:
      <p>Here’s to the crazy ones, the misfits, the rebels, the troublemakers, the round pegs in the square holes… <fn=1>text aaaaaa</fn> the ones who see things <fn=2>text bbbbbb</fn> differently </p>
      that mean i want move text body in tag fn1 to note1!
      some body help me!!
        Vuvanvui Vui
        somebody help me pls
          Hello, @vuvanvui-vui,
          UPDATED 03-07-2018 ( search regex changed in order to match a several digits number ! )
          Not totally sure that it’s what you want to !
          Assuming, for instance, the example text, below, where :
          • The first line contains the note3 and note4 marks
          • The second line contains the note1 and note2 marks
          • The third line contains the note5 and note6 marks
          • Somewhere, afterwards, a line beginning with, at least, 3 equal signs ( Note that this sign must NOT be used, anywhere in the current file. You may choose an other symbol, like -, @, ~, #, /, … )
          • Then, all the <fn=#...#>text ......</fn> replacement marks, in a list, with one per line
          <p>Here’s to the crazy ones, the misfits, the rebels, the troublemakers, the round pegs in the square holes… note3 the ones who see things note4 differently </p>
          <p>Here’s to the crazy ones, the misfits, the rebels, the troublemakers, the round pegs in the square holes… note5 the ones who see things note6 differently </p>
          === Replacement Marks ===
          <fn=3>text cccccc</fn>
          <fn=4>text dddddd</fn>
          <fn=5>text eeeeee</fn>
          <fn=6>text ffffff</fn>
          Then :
          • Open your file in N++ OR just copy / paste all the text, above, in inverse video, in a new tab ( Ctrl + N )
          • Type in the regex (?-i)\bnote(\d+)\b(?s)(?=.*\R((?-s)<fn=\1>.*))|^===.+ in the Find what: zone
          • Type in the regex ?2\2, in the Replace with: zone
          • Tick the Wrap around option and select the Regular expression search mode
          • Click, once, on the Replace All button ( or several times on the Replace button ! )
          Et voilà ! You should get the following text :
          <p>Here’s to the crazy ones, the misfits, the rebels, the troublemakers, the round pegs in the square holes… <fn=3>text cccccc</fn> the ones who see things <fn=4>text dddddd</fn> differently </p>
          <p>Here’s to the crazy ones, the misfits, the rebels, the troublemakers, the round pegs in the square holes… <fn=5>text eeeeee</fn> the ones who see things <fn=6>text ffffff</fn> differently </p>
          P.S. :
          Next time, if you would like to, I’ll explain how this regex S/R works :-))
          Vuvanvui VuiV 1 Reply Last reply Reply Quote 1
            Vuvanvui Vui @guy038
            @guy038 thanks you verymuch sir!, ;)
            P/S: Next time, if you would like to, I’ll explain how this regex S/R works :-)) (i’m understand)
              Vuvanvui Vui
              hi @guy038 if i want to:
              can you help me?
                Hi, @vuvanvui-vui,
                I’m sorry, but it’s not very clear what you would like to :
                • Are the lines <p>Here’s to........differently </p> consecutive or embedded among other lines ?
                • Are the lines <fn=#>text aaaaaa</fn> located anywhere, in your file or mixed with the <p>Here’s to........differently </p> ones ?
                In other words, could you show us :
                • The text ( or part of it ), what you get, presently, before process
                • The text that you expect to, after process
                It’s always better to work with true material !
                Note that, may be, it won’t be possible to get it with regular expressions, but, ONLY, with a scripting language, as the Lua or Python plugin !
                If your file contents are not confidential, you could, also, send me an e-mail, with your file attached, at :
                  Vuvanvui Vui
                  thanks @guy038 , I started to really enjoy python, thankyou verymuch :)
