    Customize Toolbar 4.1 (64-bit) released
    4 Posts 3 Posters 5.4k Views 2 Watching
    • dave-userD Offline
      dave-user
      Customize Toolbar 4.1 (64-bit) has been released.
      The x64 version is available for download at:
      https://sourceforge.net/projects/npp-customize/files/Customize Toolbar v4.1/CustomizeToolbar_4_1_x64.zip/download
      The 64-bit version is functionally identical to the 32-bit version.
      • ArkadiuszMichalskiA Offline
        ArkadiuszMichalski
        Can you add option to overwrite tooltip for icon? Now it’s the same as command but sometimes I don’t remember where this command comes from and must open CustomizeToolbar.btn file. In this file the last value can do that thing. So rules can looks like this:
        Menu,Menu2_or_Command,Menu3_or_Command,Menu4_or_Command,Icon,Tooltip
          ArkadiuszMichalski
          And one more thing, is there any comments syntax that we can use on CustomizeToolbar.btn file?
          • MAPJe71M Offline
            MAPJe71
            @dave-user any plans on making the source available on SourceForge or GitHub?
            • ArkadiuszMichalskiA ArkadiuszMichalski referenced this topic on
