    nul nul nul problem notpad++
    nul nul
    6 Posts 4 Posters 6.9k Views 3 Watching
    • Sagor Ali BDS Offline
      Sagor Ali BD
      I wrote so many text in notpad++ & also saved ,suddenly electricity gone.After some time have restart my computer then i opened notpad++ and it was showing me all date nul nul nul nul nul…
      so how can i get back may all text which i wrote.
      please help me.
      mdsagorali033@gmail.com
      • 古旮古 Offline
        古旮
        First go to the folder that contains notepad++.exe, then go to backup subfolder. There might be auto-saved files.
        • kgbmeK Offline
          kgbme
          Hey, it’s not in Program Files, but rather in %appdata%\Notepad++\backup
          https://ibb.co/cejOS7
            Sagor Ali BD
            but it’s also showing me all text nul nul nul…
              Scott Sumner @Sagor Ali BD
              @Sagor-Ali-BD
              This is a known issue. See this thread and the many other threads/issues it references.
              Regarding where backup files may reside:
              • If you use the “installed” version of Notepad++, you would want to look in the %APPDATA% path
              • If you use the “non-installed” version, look in the same path as the Notepad++.exe file
                Sagor Ali BD
                I am using installed version of Notpad++
                And i checked by run> %APPDATA% path and found the file when i opened this it is also showing was same condition.
