    Replace Help
    3 Posts 2 Posters 1.6k Views 1 Watching
    • BortfiveB Offline
      Bortfive
      Hi guys,
      I am trying to replace
      That
      Hint “Any Text Here”
      With
      [“Any text Here”] spawn life_fnc_hint
      The Any text here, is not the text that i want, Its like that
      https://i.imgur.com/ZGJf93q.png
      I have a lot of work to do if anyone found the way to do it :)
      https://i.imgur.com/WOlws9w.png
      Can anybody try to help me?
      Thank you in advance.
        Hello, @bortfive,
        • First, I strongly advice you to backup your 271 files !
        • Then, test my regex search/replacement, below, on one file, only !
        • Copy **one of your files in a new tab ( Ctrl + N )
        • Type in the regex (?-is)^hint (".+?"); , in the Find what: zone
        • Type in the regex [\1] spawn life_fnc_hint , in the Replace with: zone
        • Tick the Wrap around option
        Et voilà !
        Note that, only, all ranges hint ".......";, beginning the lines, are matched !
        So, given the initial text, below :
        hint "Ahora ves los nombres de los jugadores";   hint "This is a test !";
        hint "  Has dejado de ver los nombres de los jugadores   ";
        You should obtain :
        ["Ahora ves los nombres de los jugadores"] spawn life_fnc_hint   hint "This is a test !";
        ["  Has dejado de ver los nombres de los jugadores   "] spawn life_fnc_hint
        Now, if you may have several zones hint ".......";, in a same line, change the search regex to :
        (?-is)hint (".+?");
        And, you’ll get the following text :
        ["Ahora ves los nombres de los jugadores"] spawn life_fnc_hint   ["This is a test !"] spawn life_fnc_hint
        Notes :
        • First, the (?-is) modifiers :
          • Force the regex engine to consider any dot as matching one single standard character ( and not the EOL ones )
          • Force the search to be sensitive to case ( => So, a line HINT "...."; or Hint "...."; is not matched ! )
        • The part .+? represents the shorter range of characters between the two boundaries "
        • As this range "....." is surrounded by parentheses, it is stored as group 1
        • In replacement, the \1 syntax stands for the group 1 contents
        BortfiveB 1 Reply Last reply Reply Quote 0
        • BortfiveB Offline
          Bortfive @guy038
          @guy038 i will try it, u are the best bro <3
