    Sorting by a key with offset and length
    sort files
    4 Posts 4 Posters 2.9k Views 3 Watching
    • Abhay GokhaleA Offline
      Abhay Gokhale
      How to sort a file at a certain offset? e.g. my sort key is offset 5 length of 2
        Scott Sumner @Abhay Gokhale
        @Abhay-Gokhale
        Well you can try making a column selection first and then execute Edit (menu) -> Line Operations -> Sort Lines…
        Example:
        Imgur
        It may work for you. I’ve found that Notepad++ doesn’t do a stable sort…so YMMV depending upon what you are doing…
        • J Offline
          Jim Dailey
          @Abhay-Gokhale You could always type sort /h in a command shell.
            Hello, @abhay-gokhale, and All,
            The is a safe way to sort with an offset, in Notepad++. The trick is to copy the key sort, in front of each line to be sorted ;-))
            Let’s start with that sample text ( A long line from the license.txt file, split in several lines )
            The licenses for most software are designed to take away your freedom to share
            and change it. By contrast, the GNU General Public License is intended to
            guarantee your freedom to share and change free software--to make sure the
            software is free for all its users. This General Public License applies to
            most of the Free Software Foundation's software and to any other program whose
            authors commit to using it. (Some other Free Software Foundation software is
            covered by the GNU Library General Public License instead.) You can apply it
            to your programs, too.
            I, simply, inserted a 5 digits number, surrounded by a space character, at column 11 of each line, giving the following text :
            The licens 37529 es for most software are designed to take away your freedom to share
            and change 12345  it. By contrast, the GNU General Public License is intended to
            guarantee  94113 your freedom to share and change free software--to make sure the
            software i 88060 s free for all its users. This General Public License applies to
            most of th 46931 e Free Software Foundation's software and to any other program whose
            authors co 88060 mmit to using it. (Some other Free Software Foundation software is
            covered by 88060  the GNU Library General Public License instead.) You can apply it
            to your pr 62473 ograms, too.
            That five digits number will be the expected key sort. Now, applying the regex S/R :
            SEARCH (?-s)^.{11}(.{5}).+
            REPLACE \1\x20\x20\x20$0
            you should get the text :
            37529   The licens 37529 es for most software are designed to take away your freedom to share
            12345   and change 12345  it. By contrast, the GNU General Public License is intended to
            94113   guarantee  94113 your freedom to share and change free software--to make sure the
            88060   software i 88060 s free for all its users. This General Public License applies to
            46931   most of th 46931 e Free Software Foundation's software and to any other program whose
            88060   authors co 88060 mmit to using it. (Some other Free Software Foundation software is
            88060   covered by 88060  the GNU Library General Public License instead.) You can apply it
            62473   to your pr 62473 ograms, too.
            Then, after running the sort operation ( Edit > Line Operations > Sort Lines Lexicographically Ascending, you get :
            Notice that, when the key sort is identical ( case of 88060 ), for several lines, the lines are, in addition, sorted, according to the entire line contents ! ( authors - covered - software )
            Finally, using this second simple regex S/R, below, we get rid of the temporary key sort, at column 1 :
            SEARCH (?-s)^.{5}\h+
            REPLACE Leave EMPTY
            and obtain our expected text :
            Et voilà !
