    NP++ 64bit plugins
    6 Posts 4 Posters 9.5k Views 2 Watching
    • Kym Farnik208K Offline
      Kym Farnik208
      What is the © status of the 32 bit plugins?
      I would be happy to convert some to 64bit, which is holding me back from switching versions.
      Thanks , Kym
      • chcgC Offline
        chcg
        See https://github.com/bruderstein/npp-plugins-x64/blob/master/plugins/plugins64.xml for the currently available plugins for 64bit at the plugin manager. The current list of all 32bit ones https://github.com/bruderstein/npp-plugins-x64/blob/master/plugins/plugins_template.xml.
        Which one are you missing to be converted?
        • logg-sarL Offline
          logg-sar
          @chcg
          The Hex-Viewer Plugin.
          logg-sarL 1 Reply Last reply Reply Quote 0
          • logg-sarL Offline
            logg-sar @logg-sar
            @logg-sar said:
            @chcg
            UUUps - just found: https://notepad-plus-plus.org/community/topic/14264/i-made-hexeditor-x64-working-what-next
            • JustACatJ Offline
              JustACat
              Hello!
              How about PyNPP plugin?
              https://github.com/mpcabd/PyNPP/
              Thx.
              • chcgC Offline
                chcg
                See https://github.com/mpcabd/PyNPP/pull/2#issuecomment-362668391, unfortunately no reaction so far.
