    Keep only specific links
    4 Posts 2 Posters 1.4k Views
    • T CT
      T C
      Hi.
      How can I keep links like this:
      https://archiveofourown.org/works/120628
      and not links like these:
      https://archiveofourown.org/works/120628#comments
      https://archiveofourown.org/works/120628/bookmarks
      https://archiveofourown.org/works/120628?show_comments=true#comments
      Thanks so much
      Scott SumnerS 1 Reply Last reply Reply Quote -1
      • Scott SumnerS
        Scott Sumner @T C
        @T-C
        What you want is a little loosely defined. For example, this will do it, but I sense you want something more generic over the whole expression:
        Find what zone: (?-s)https://archiveofourown\.org/works/120628(?=[#/?]).+\R
        Replace with zone: make sure this is EMPTY
        It also assumes that the lines end where shown above by the OP, but this is somewhat of an arbitrary assumption…
        Hmmm…don’t know that this actually deserves a down-vote…whomever did that…
        • T CT
          T C
          Another option was to mark lines that had only links like this:
          https://archiveofourown.org/works/14272356
          The numbers in bold are different every time.
          • Scott SumnerS
            Scott Sumner @T C
            @T-C
            Again, what you are trying to achieve is vague. You’re not going to get the best help that way (and you may even get down-voted again).
            So…first you wanted to delete text, now you want to mark text…which is it?
            You can match a number that is different every time by using \d+ in the expression where the number occurs.
