    Need help defining my own language
    10 Posts 4 Posters 3.1k Views 3 Watching
    • Juan Pablo BollettaJ Offline
      Juan Pablo Bolletta
      Hello, I’m trying to make my own language. It is for the text input for a specific program, where the number 1.00 has special significance. I would like to highlight it whenever it appears no matter the context. Sometimes it has a prefix (other numbers) sometimes it doesn’t.
      Any clues on how to do this? I have tried putting 1.00 as operator 1, but it only works when it has something before, such as in 21.00, but not with 1.00
      Thanks!
      Claudia FrankC 1 Reply Last reply Reply Quote 2
        Claudia Frank @Juan Pablo Bolletta
        @Juan-Pablo-Bolletta
        sorry not 100% clear to me, you only want to color 1.00 or 21.00 as well?
          Juan Pablo Bolletta
          I want to color 1.00 when it appears as 1.00 and also when it appears as xx1.00, being x anything. All instances of 1.00 regardless of context.
            sorry, seems I wasn’t clear - I got that you want to color 1.00 - what I don’t know
            is about the 21.00. Should the whole decimal be colored or only 1.00 and 2 being left
            with the default color of the text.
              Juan Pablo Bolletta
              Oh, sorry, maybe I misunderstood. It is the same, both will work for what I want to do.
              Can you tell me how to do both, then I will pick what works better for the users?
              Claudia FrankC 2 Replies Last reply Reply Quote 0
                ok - let me think about it - I guess this easy task isn’t easy solvable.
                  sorry - but it looks like udl doesn’t support this at the moment.
                  The native workarounds I see are macro and mark feature from find dialog
                  or using style token feature but this involves manual execution.
                    Juan Pablo Bolletta
                    OK, I will keep using the current version that highlights 1.00 when it has something immediately before. Thank you for your time!
                    • Gogo NeatzaG Offline
                      Gogo Neatza
                      Use Notepad++ with the RegEx Helper plugin.
                      Using in the plugin this expression “(\d{2,3}.00)|(1.00)”
                      the plugin will match and highlight things like 1.00 , x1.00 or xx1.00 anywhere in the current file.
                        Scott Sumner @Gogo Neatza
                        A downside there is that the RegEx Helper has to be manually activated upon every run of Notepad++, and that regex entered into its UI again. At least that my understanding of that plugin.
                        Seems like the OP would like something more “automatic”.
