    Problems with opening files for editing
    1 Posts 1 Posters 793 Views 1 Watching
    • BillDietrichB Offline
      BillDietrich
      Windows 10 using NPP 7.5.6. I have a folder with say 100 HTML files in it. NPP will only open about 10 at a time ? No way to select all 100 and open them in one operation ?
      Also, when opening the FileOpen dialog, if I selected type HTML last time, it remembers that I want HTML docs, but the file list actually shows ALL file types. I have to change to some other type, then back to HTML, for it to update the file list to show only proper type of files. This is a bug, I think.
