    Open folder as project issue
    2 Posts 2 Posters 1.1k Views 2 Watching
    • Brandon CarterB Offline
      Brandon Carter
      open folder as project only allows me to select desktop for some reason anyone know why or how to fix it?
      Also I’m looking for a autosave every x amount of seconds plugin that works with the newest notepad++ if anyone knows of one thanks.
        Claudia Frank @Brandon Carter
        @Brandon-Carter
        Could you please a little bit more specific what exactly you are doing?
        For more information see here.
        What is the issue with the ones available via plugin manager?
        Or are you affected by this.
