    Help Parsing Datafile and removing unwanted strings
    6 Posts 2 Posters 2.2k Views 1 Watching
    • Frederick DalmeidaF Offline
      Frederick Dalmeida
      I am tasked with parsing some very large datafiles that look like the examples below. I am new to RegEx and Notepad++ and will get there eventually but for now I just need help getting over this hurdle. The desired output is what I’m looking to accomplish. Help anyone?
      Provided Data
      þRecordIDþþFullPathþ
      þREC00000001þþ\Network Share\Mike Ren Files\C\Users\Mike Ren\Documents\Outlook Files\MikeR.ost\Root - Mailbox\IPM_SUBTREE\Inboxþ
      þREC00000002þþ\Teams\Users\John Doe\AppData\Local\Microsoft\Outlook\JohnDoe.ost\Root - Mailbox\IPM_SUBTREE\Inboxþ
      þREC00000003þþ\Network Share\John Doe Old Laptop #1\D\Users\JohnDoe\AppData\Local\Microsoft\Outlook\outlook.ost\Root - Mailbox\IPM_SUBTREE\Inbox\Finance\FW: FY12 Audit Reportþ
      þREC00000004þþ\Network Share\Jane Smith Data\C\Users\JaneSmith\Documents\Outlook Files\archive.pst\Top of Outlook data file\Inboxþ
      þREC00000005þþ\Backups\Mary Larson\HDD1234\E\Back-up (4.16.2018)\archive.pst\Top of Outlook data file\Inbox\Billing - West Regionþ
      Desired Output
      þRecordIDþþEmail ContainerþþEmail Folder Pathþ
      þREC00000001þþMikeR.ostþþRoot - Mailbox\IPM_SUBTREE\Inboxþ
      þREC00000002þþJohnDoe.ostþþRoot - Mailbox\IPM_SUBTREE\Inboxþ
      þREC00000003þþoutlook.ostþþRoot - Mailbox\IPM_SUBTREE\Inbox\Finance\FW: FY12 Audit Reportþ
      þREC00000004þþarchive.pstþþTop of Outlook data file\Inboxþ
      þREC00000005þþarchive.pstþþTop of Outlook data file\Inbox\Billing - West Regionþ
        Hello, @frederick-dalmeida, and All,
        As you did not provide lot of information, and in order to, exactly, match your text, I supposed some points :
        • Regarding the Header line :
          • Begins with the string RecordID, surrounded by the þ character and followed by <DC4>þ, which should remain after replacement
          • Ends with the word FullPath, followed with the þ character
        • Regarding the Record lines :
          • Begins with the string þREC, followed by 8 digits and the string þ<DC4>þ, unchanged after replacement )
          • The parts beginning with, either, the string Root - Mailbox or the string Top of Outlook data file, up to the end of line, must be, also, unchanged after replacement
          • The range between two \, placed before the two strings just above, must be rewritten, followed with the string þ<DC4>þ
        So :
        • First, backup the file(s), concerned by this S/R ! ( IMPORTANT )
        • Tick the Wrap around option
        Fill the Search what: and Replace with: zones, with the regexes, below ( Copy/Paste ) :
        SEARCH (?-is)^\x{FE}REC\d{8}\xFE\x14\xFE\K.+\\(.+?)\\(?=(?:Root - Mailbox|Top of Outlook data file))|^\x{FE}RecordID\xFE\x14\xFE\K(Full)(?=Path\xFE$)
        REPLACE (?1\1\xFE\x14\xFE)(?2Email\x20Container\xFE\x14\x{FE}Email\x20Folder\x20)
        • Click on the Replace All button, exclusively ( Do not use the Replace one ! )
          Frederick Dalmeida
          @guy038
          Thanks for the reply. You captured the structure correctly. The Regex that you provided only replaces the values in the header row and does not perform the update (search/replace) on the body of the data. Thanks!
            Hi, @frederick-dalmeida, and All,
            Ah, OK ! Probably, the body part of your initial text is indented, as shown below :
            In that case, just add the regex \h*, after the ^ symbol, at the beginning of the search regex, which becomes :
            SEARCH (?-is)^\h*\x{FE}REC\d{8}\xFE\x14\xFE\K.+\\(.+?)\\(?=(?:Root - Mailbox|Top of Outlook data file))|^\x{FE}RecordID\xFE\x14\xFE\K(Full)(?=Path\xFE$)
            The indentation will be kept, after the replacement :-)
              Frederick Dalmeida
              @guy038
              That did the trick. Thank you!!
              ps.
              I later found that there were variations in the RecordIDs and some other variations in the email container types and Top Folders so I made some adjustments to account for those variations:
              SEARCH (?-is)^\x{FE}.*?\xFE\x14\xFE\K.+\(.+?)\(?=(?:Root - |Top of |EAD2EF20-))|^\x{FE}RecordID\xFE\x14\xFE\K(Full)(?=Path\xFE$)
              Again, Thank you so much for the help! You are a life saver.
                Probably, your regex should have that form !
                (?-is)^\x{FE}.*?\xFE\x14\xFE\K.+\\(.+?)\\(?=(?:Root - |Top of |EAD2EF20-))|^\x{FE}RecordID\xFE\x14\xFE\K(Full)(?=Path\xFE$)
                or may be, if we care about possible indentations :
                (?-is)^\h*\x{FE}.*?\xFE\x14\xFE\K.+\\(.+?)\\(?=(?:Root - |Top of |EAD2EF20-))|^\x{FE}RecordID\xFE\x14\xFE\K(Full)(?=Path\xFE$)
                For documentation about regular expressions, see here
                As you managed to adapt my regex to your needs, I suppose that you correctly understood its syntax :-) But I don’t mind giving you additional information, if necessary !
