    How to remove text between two specified strings using Notepad++?
    3 Posts 3 Posters 13.6k Views 1 Watching
    • PRATAP CHAVAP Offline
      PRATAP CHAVA
      I have following lines of data
      File created by
      Status 23:
      Status 24:
      Status 25:
      Status 26:
      Status 27:
      Status 28:
      Status 29:
      Status 30:
      Status 31:
      Address
      Address 112: 044 0891.
      Address 113: 044 1502.
      Message log (200 messages)
      Message 1:
      Message 2:
      Message 2:
      Message 2:
      Message 2:
      Message 2:
      I wish to delete text between line 1(File created by ) and upto line “Message log (200 messages)”.
      Can someone please provide some suggestions and thoughts on this?
      Thank you very much.
      • chcgC Offline
        chcg
        Via regex search&replace:
        Search term:
        (?s)^\t*File created by(.|\r\n)*?Message log
        Replace.with:
        Message log
        See also https://notepad-plus-plus.org/community/topic/15765/faq-desk-where-to-find-regex-documentation
        and most probably there are more elegant searches possible.
          Hello, @pratap-chava and All,
          Regarding your needs, I think that a suitable regex S/R could be :
          SEARCH : (?s-i)^File created by.+?\RMessage log.+?$\R
          REPLACE Leave Empty
          Don’t forget to select the Regular expresion search mode and to tick the Wrap-around option
          Notes :
          • At beginning of the regex, the modifiers (?s-i) mean that :
            • The . dot regex character will match any single character ( Standard and EOL chars )
            • The search is performed in a sensitive way. If you prefer insensitive matches just change that part with (?si) !
          • Then the part File created by.+?\RMessage log looks, from beginning ( ^ ) of line, for any text, beginning with File created by and ending at the first expression Message log, preceded by a line-break ( \R )
          • Now, the final part .*?$\R tries to match a range of any character, ending at the nearest end of line ( $ ), and followed with a line-break ( \R )
          And, due to the empty replacement zone, all that block of text is, then, simply deleted !
