Enabling Synchronize Vertical and Horizontal Scrolling
I want to have two file displayed side by side, with out using the compare plugin. How do I accomplish that? I thought I could just enable the Synchronize Vertical an Horizontal Scrolling option in the view menu, but they are grayed out.
Right-click the tab of one of the desired files and choose Move to Other View. Then, click the tab for the other file. Now both files should be active, but in two different views. If they are one-on-top-of-the-other instead of side-by-side, right-click the border between them and choose one of the options in the little box that pops up. After that the two files should be side-by-side. And the Synchronise menu options should be enabled.
