    Is there any way to have N++ start in overwrite mode, instead of insert mode?
    4 Posts 3 Posters 2.5k Views
    • Mike ManionM
      Mike Manion
      Whenever I start N++, I always have to press “Insert” on my keyboard (or click where it says “INS” in the bottom right of the status bar) to toggle INS/OVR because I always want it to be in overwrite mode instead of insert mode.
      Is there a setting that would make N++ automatically start in overwrite mode instead of insert mode? I think most text editors have such a setting, but I can’t find it in N++.
      If not, is there any way to run a simple script at startup (I use Windows 10), that makes it automatically change from INS to OVR every time I launch it?
      Thanks devs! I’m very happy with this software so far!
      Scott SumnerS 1 Reply Last reply Reply Quote 2
      • Scott SumnerS
        Scott Sumner @Mike Manion
        @Mike-Manion
        As a fan of the Pythonscript plugin, I would do it in my startup.py script with this command:
        editor.editToggleOvertype()
        If you use the secondary view ever, you may want to do:
        editor1.editToggleOvertype()
        editor2.editToggleOvertype()
        I’m sure there are other ways as well…
        • Mike ManionM
          Mike Manion
          Thanks, it worked!
          For anyone needing more detail, here are the steps:
          • Click Plugins -> Plugin Manager.
          • Check the box next to “Python Script”, then click the “Install” button to install it.
          • Click Plugins -> Python Script -> Configuration.
          • In the “Initialisation” dropdown, change it from LAZY to ATSTARTUP.
          • Add the suggested line to the end of C:\Program Files (x86)\Notepad++\plugins\PythonScript\scripts\startup.py
          • Oanh SchlesingerO
            Oanh Schlesinger
            I had this question too. Finding the answer was easy. I thought I was in for hours of searching. I looked at only one other place before coming to this one and to my surprise the question/answer was staring at me in the face. The entry outlining the steps was helpful indeed. Notepad++ transformed the way I do many things. I am just now learning and already understand it’s value. Keep up the good work. My performance is based on the knowledge of others. Thanks!
