    Select links by double clicking them? (or a specific part of them?)
    7 Posts 2 Posters 3.0k Views 2 Watching
    • Caribou AiléC Offline
      Caribou Ailé
      I would like to know if there is a way to select a link easily with a double click. I haven’t found out anything about this so far!
      When you have many to modify in big text docs, it can save you a lot of time.
      Selecting link with the usual "drag cursor " way is not very convenient, and often screws up with horizontal scrolling for long links.
      Thanks!
        Scott Sumner @Caribou Ailé
        @Caribou-Ailé
        How about a single click? Go to Settings (menu) and choose Preferences… and then:
        Imgur
          Scott Sumner
          Ahhh…maybe you just want to select them in Notepad++, not goto them…the problem with easily selecting them is defining a pattern for them that works for all possible links…if you can do that, then there is a reasonable way to select them.
            Caribou Ailé
            Thanks Scott for your quick answer!
            But you’re right, the problem is to select them, not to go to the link ^^
            the pattern would be selct between “” (“link”). That should work without problems, but i haven’t seen where I can set this .
            PS: excuse me, I needed to wait 1200 seconds to answer as a new user :/
              @Caribou-Ailé
              The wait is OVER! I have given you 2 upvotes. :-)
              Links in general aren’t surrounded by ". Are you saying that for your case, they always are? If so, then as long as you are slightly in front of a link, you could perform this search and it will leave your link-text selected (what is inside the double-quotes), assuming well-formed links of course:
              Find what zone: (?<=")[^"]+
              Backward direction: unticked
              You could record this into a macro and bind it to a keycombo for maximum ease-of-use.
                Caribou Ailé
                Thanks a lot for your answer and the upvotes!
                I forgot to mention it was HTML links, that’s why they where between “”.
                In order to not select other HTML code, I have modified to (?<=href=“)[^”]+ and it works like a charm, thanks a lot!
                I will see how to make a macro!
                  Caribou Ailé
                  It works perfectly, great!
                  Thank you again!
