    Need regex for incremental by 1
    8 Posts 3 Posters 13.5k Views 3 Watching
    • ganesan govindarajanG Offline
      Hi all,
      I have the texts like "indent=“0”, indent=“1”, indent=“0”, indent=“2” etc in several places in the xml file.
      I wanted to replace with incremental by 1 in to the each value as indent=“1”, indent=“2”, indent=“1”, indent=“3” etc.
      Is there any possible way available in notepad++?
      thanks
      ganesang
        Scott Sumner @ganesan govindarajan
        @ganesan-govindarajan
        There is no way to do it within Notepad++ without scripting. See the following:
        • https://notepad-plus-plus.org/community/topic/15318/replace-text-with-incremented-counter
        • https://notepad-plus-plus.org/community/topic/12967/replace-string-across-multiple-files-and-increment-value
          Scott Sumner @Scott Sumner
          Well…it depends upon how much effort you want to expend…
          Say you used the Edit (menu) -> Column Editor… feature (twice) to create a two column table of incrementing numbers (it could be a long table, I just show a short one):
          0 1
          1 2
          2 3
          3 4
          and then you put a line of dashes (or any sequence of characters that does not appear in your data) and this table AFTER your data in your Notepad++ tab:
          I have the texts like "indent="0", indent="1", indent="0", indent="2" etc in several places in the xml file.
          0 1
          1 2
          2 3
          3 4
          Then a regex replacement could solve this problem:
          Invoke Replace dialog (default key: ctrl+h)
          Find what zone: (?-i)indent="(\d+)"(?s)(?=.*?^-----.*?^\1\h+(\d+))
          Replace with zone: indent="\2"
          Wrap around checkbox: ticked
          Search mode selection: Regular expression
          Action: Press Replace All button
          Results:
          I have the texts like "indent="1", indent="2", indent="1", indent="3" etc in several places in the xml file.
          0 1
          1 2
          2 3
          3 4
          After that you simply remove the line of dashes and the table…
          ganesan govindarajanG 1 Reply Last reply Reply Quote 2
            ganesan govindarajan @Scott Sumner
            @Scott-Sumner
            Thanks very much!
            I will do this way…
            • Vasile CarausV Offline
              Vasile Caraus
              ok, and another exemple.
              If I have 100 .html pages, and in each page I have such as:
              page 1:
              $item_id = 0001;
              page 2:
              $item_id = 0002;
              page 3:
              $item_id = 0003;
              How can I replace with incremental by 1 in to the each value, in order to obtain:
              page 1:
              $item_id = 0002;
              page 2:
              $item_id = 0003;
              page 3:
              $item_id = 0004;
              etc…
                Scott Sumner @Vasile Caraus
                What is the meaning of “page” in this context…do you have 100 html files and you want to do this operation on each file ?
                  Vasile Caraus
                  I have 100 .html pages, and each page has a unique string. For exemple, page 1 has $item_id = 0001;, page 2 has $item_id = 0002; etc…
                  I want to replace in each file with incremental by 1 in to the each value
                    @Vasile-Caraus
                    It sure seems like you could use a variation on the technique described above:
                    • key concept: use Replace All in All Open Documents or Replace in Files for most of the action
                    • create a delimiter and a lookup-table running from 0 to 101 (or whatever), probably all on one line is best, e.g. \r\n-----0:1,1:2,2:3,3:4,4:5,5:6,6:7,7:8,8:9,9:10,10:11,… ; you can do this with the column-editor features to ease the pain…followed by some editing…
                    • regex replace \z in each file with the lookup table string created above (this will add the table at the end of each file)
                    • run a regex replacement (on all files) like described above for the other poster but customized for your data, e.g. \$item_id = \d+; and the contents of the lookup-table string
                    • craft another regex replacement to remove the delimiter and lookup-table from all files
