    Regexp help
    3 Posts 2 Posters 991 Views
    • Luther BlissetL
      Luther Blisset
      Hi all,
      I would like to replace text between two tags with a new line (\n).
      The starting tag is: <!-- - <a href=“#”>
      The ending tag is: <strong>
      Example:
      • input:
        textbefore<tag1>abcdefg<tag2>textafter
      • output:
        textbefore
        textafter
      Could someone be some kind to help me?
      Thanks in advance,
      cid
      Scott SumnerS 1 Reply Last reply Reply Quote 2
      • Scott SumnerS
        Scott Sumner @Luther Blisset
        @Luther-Blisset
        Sure…fairly easy. In fact, so easy that if you know the term “Regexp” then you should be able to get this one yourself. But here you go:
        Find what zone: (?-s)<tag1>.+?<tag2>
        Replace with zone: \r\n <—if using Windows line-endings
        Search mode selection: Regular expression
        • Luther BlissetL
          Luther Blisset
          Done, Thanks for your help!
          I’m familiar with regexp concept but never used them before.
          Best regards,
          cid
