    How to set background color for a own style
    howbackgournd
    1 Posts 1 Posters 950 Views 1 Watching
    • blender advisorsB Offline
      blender advisors
      Hi!
      Basicly my purpose is to use certain tabs as a sticky note.
      Do you know how is it possible to change the whole background to yellow, but only for either an extension, or for a user defined style?
      I don’t find such an option.
      The background color in “Language -> Define your language” changes the background only under the letters.
      Changing the global background color at Settings -> Style Configurator then changes the background everywhere, which is not good either.
      Thanks a lot!
      Jason
