    Perl sigils: select sigils as part of variable with Double Click and Shift+Left/Right Arrows
    4 Posts 3 Posters 964 Views
    • gapsfG
      gapsf
      Let consider Perl code like:
      $var_name = 5;
      @var_name =(1, 5);
      %var_name = (a => 5);
      $coderef = &var_name;
      As for now when I double click on ‘var_name’ NPP selects ‘var_name’ part of line only, but not $@%& symbols.
      If I try to select ‘var_name’ by pressing ‘Shift+ Left Arrow’ when cursor at the end (or just after) of the ‘var_name’ NPP also selects
      only part of the string without $@%& symbols.
      Is it possible to configure NPP to select $@%& symbols as a part of the identifier (word) for specific languages, not globally?
      • AZJIO AZJIOA
        AZJIO AZJIO
        And why separately? Are they interfering?
        • Scott SumnerS
          Scott Sumner @gapsf
          @gapsf
          Where you say “Shift+Arrow” don’t you mean “Shift+Ctrl+Arrow”?
          Maybe the following will help you:
          Invoke Settings menu and choose Preferences…, then:
          Imgur
          In the screenshot I only added $…add others as you like.
          gapsfG 1 Reply Last reply Reply Quote 4
          • gapsfG
            gapsf @Scott Sumner
            @Scott-Sumner
            Yep, “Shift+Ctrl+Arrow”.
            Your advice helped.
