    Search and replace inside the same blocks
    4 Posts 3 Posters 1.3k Views 2 Watching
    • Anatol SamA Offline
      Anatol Sam
      Is it possible to do search and replace only inside the same blocks of several strings
        Anatol Sam
        For example: I marked a group of five lines. I want to find the same groups throughout whole text and make the same replacements for each of them. Is it possible?
        • dinkumoilD Offline
          dinkumoil
          You need a featur called “multi-line find and replace”. E.g. the ToolBucket plugin contains it.
            Hello, @anatol-sam,
            I think so. But we need some details, about the text to change !
            Simply, give us one or several example(s) of the bunch(es) of text which you want to search AND the corresponding text which you expect, for each bunch, after the S/R operation !
            To be sure that your text will NOT be interpreted with the Markdown syntax, used on this site, simply wrap all your BEFORE and AFTER stuff with, either :
            • The starting line ```z and the ending line ``` ( using the backquote / backtick character ` )
            • The starting line ~~~z and the ending line ~~~ ( using the tilde character ~ )
            For instance :
            I have :
            ```z
            Your BEFORE stuff
            And I would like :
            ~~~z
            Your AFTER stuff
            So, in short, give us some material to think about :-))
            Best Regards
