UTF-8 option has a bom problem! Please give us utf-8 without bom option again
A few days ago, i changed my site’s wp-config file on notepad++ and saved as UTF-8. But i had a problem about bom. Because of this fact, i can’t reached my admin panel of my site. And my site’s hosting company technical supporters said me that your wp-config file was with bom, we changed it as without bom. And then I can reach my admin panel again. I think you’re wrong; UTF-8 is not UTF-8 without bom. Please fix it. Cause we have to change htaccess file and i don’t have any solution how can I save UTF-8 without bom!
I guess you use Notepad++ with a russian locale. This locale has the known problem that the menu entries regarding UTF-8 in the
Encodingmenu are not in sync with the encoding indicator in the status bar of Notepad++.UTF-8 without BOM:
- In the
Encodingmenu (translated): Encode in UTF-8 without BOM - In the status bar: UTF-8
UTF-8 with BOM:
- In the
Encodingmenu (translated): Encode in UTF-8 - In the status bar: UTF-8-BOM
A fix is on its way and will be part of the next release, see here.
As a temporary workaround you could integrate the patch above manually into your
russian.xmlfile. You can find this file in<Installation-Path-of-Notepad++>\localization.After you did that there are 2 possible ways to activate the changed language file:
- Start Notepad++, switch to an arbitrary language and then back to russian again.
- Copy the changed
russian.xmlfile toC:\Users\<Username>\AppData\Roaming\Notepad++and rename it tonativeLang.xml.
Please note: You have to follow only one of the two steps above!
- In the
