Pls help
Since few days i"m facing a problem . When i want to open notepad++ it shows “Dll signature verification failed” also “Library verification failed”. i’m using current version notepad++. I have tried my best to solve it by uninstall then reinstall .
Version 7.5.9? Which kind of installation (msi or zip)? 32bit or 64bit. There is a crypto check between notepad++.exe and the corresponding SciLexer.dll to avoid security issues via hijacked dlls.
yes 7.5.9 not zip 64 bit . can you suggest variant of it ?
On which windows version? See also https://notepad-plus-plus.org/community/topic/15739/faq-desk-request-for-help-without-sufficient-information-to-help-you.
You could try a variant from https://notepad-plus-plus.org/download/v7.5.9.html. Maybe starting with
Notepad++ minimalist package 64-bit x64
