    Run the 32-bit and 64-bit versions side by side
    3 Posts 3 Posters 3.3k Views 2 Watching
    • David BaileyD Offline
      David Bailey
      I would like to install the 64-bit version on the same machine as my existing 32-bit version. Can I actually do this, as they will both end up using the same %appdata% files?
      Ideally in the end, I would like to transfer my 32-bit configuration to the 64-bit version.
      • chcgC Offline
        chcg
        To my knowledge that is not possible. The plugins need to be reinstalled/readded manually.
        The portable\zip version of N++ could be used in parallel for testing
          I, too, think portable for one is probably your best choice.
          • If you want to primarily use 32-bit, but start experimenting with 64-bit, then I would leave 32-bit installed, and run 64-bit from portable.
          • If you want to primarily use 64-bit, but want 32-bit available for non-64b plugins, then install 64-bit, check registry settings (64bit on Win10 doesn’t always associate properly: see this thread and others it references), then put 32-bit into a portable directory. This should keep all your 64-bit settings the same as you used to have on 32-bit.
          After making the portable directory, you’ll then need to install plugins for your portable (as @chcg said). Also, if you want the same settings, you can copy the XML configuration files from %AppData%\Notepad++ to the portable directory.
          Good luck.
