    Delete columns using ++ notepad
    4 Posts 3 Posters 2.2k Views 3 Watching
    • favio rodiF Offline
      favio rodi
      Hello everyone, I appeal to you to help me, I have a file of approximately 35k, in the following format
      col1:col2:col3:col4:col5
      My question is if you can combine column by column? as follows:
      col1:col2
      col1:col3
      col1:col4
      col1:col5
      col2:col3
      col2:col4
      col2:col5
      col3:col4
      col3:col5
      col4:col5
      How can I do this using notepad?
      thanks
        Scott Sumner @favio rodi
        @favio-rodi
        It might be possible. First, though, curious how that kind of data manipulation is useful. Can you explain the real-world example?
          @favio-rodi,
          It appears to me that you are trying to list all the combinations of those 5 columns, taken 2 at a time, preserving original column order. Personally, for data combinatorics, I would use a full programming language (I would use Perl; many others would use Python or Lua or some other personal favorite language; a benefit of the latter two is that there are NPP plugins available which embed copies of the programming language in NPP, and allow you direct access to the currently-open files in Notepad++, rather than making you manually deal with the file i/o portion of the code).
          Assuming it’s literally 5 columns, you can do it rather straightforwardly using a regular expression:
          • Find what: ^([^:\r\n]+):([^:\r\n]+):([^:\r\n]+):([^:\r\n]+):([^:\r\n]+)$
          • Replace with: $1:$2\r\n$1:$3\r\n$1:$4\r\n$1:$5\r\n\r\n$2:$3\r\n$2:$4\r\n$2:$5\r\n\r\n$3:$4\r\n$3:$5\r\n\r\n$4:$5\r\n
          • Search Mode = Regular Expression
          This finds 5 groups separated by colons, all on a single line; it replaces those with windows-newline(CRLF)-separated combinations columns.
          If you wanted an expression that would handle pairs of columns taken from 6 original columns, you would need one extra term in the Find What, and you would need nCr = C(n,r) = C(6,2) = 6!/4!/2! = 15 terms in the Replace With. If you want to be able to handle an arbitrary n number of columns, you would probably want to do it in a programming language – or at least generate the regular expression in a program (because manually generating the Find what and Replace with was tedious with 5 columns, and would get rather annoying pretty quickly beyond that.
          With the expression above, if I start with
          one:two:doesnt match because five 'columns' split across:
          multiple:lines
          a:b:c:d:e
          I end up with
          col1:col2
          col1:col3
          col1:col4
          col1:col5
          col2:col3
          col2:col4
          col2:col5
          col3:col4
          col3:col5
          col4:col5
          one:two:doesnt match because five ‘columns’ split across:
          multiple:lines
          a:b
          a:c
          a:d
          a:e
          b:c
          b:d
          b:e
          c:d
          c:e
          d:e
          favio rodiF 1 Reply Last reply Reply Quote 5
            favio rodi @PeterJones
            @PeterJones , thank you very much Mr. PeterJones
