Navigation
    • Search
    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Search
    XMLTools 2.4.9.2 64-bit not compatible with Notepad++ 7.5.9 64-bit
    Plugin Development
    • Brian Schepers
      Brian Schepers last edited by
      After following instructions for XML Tools 2.4.9.2 x64, I get a message that the plug-in is not compatible with this version.
      Notepad++ v7.5.9 (64-bit)
      Build time : Oct 14 2018 - 15:19:55
      Admin mode : ON
      OS : Windows 7 (64-bit)
      Plugins : DSpellCheck.dll mimeTools.dll NppConverter.dll
      Is there a way to correct this issue?
      • chcg
        chcg last edited by
        Maybe you what to use https://github.com/bruderstein/nppPluginManager/releases/tag/v1.4.12 for automatic installation. For me it is working. Otherwise you could check https://github.com/bruderstein/npp-plugins-x64/blob/master/plugins/plugins64.xml#L1228 how it is installed and redo the steps manually.
        		<download>https://sourceforge.net/projects/npp-plugins/files/XML%20Tools/Xml%20Tools%202.4.9%20Unicode/Xml%20Tools%202.4.9.2%20x64%20Unicode.zip/download</download>
        			<copy from="dependencies\libiconv-2.dll" to="$NPPDIR$\" validate="true"/>
        			<copy from="dependencies\libwinpthread-1.dll" to="$NPPDIR$\" validate="true"/>
        			<copy from="dependencies\libxml2-2.dll" to="$NPPDIR$\" validate="true"/>
        			<copy from="dependencies\libxslt-1.dll" to="$NPPDIR$\" validate="true"/>
        			<copy from="dependencies\zlib1.dll" to="$NPPDIR$\" validate="true"/>
        			<copy from="install.txt" to="$PLUGINDIR$\doc\XmlTools"/>
        			<copy from="XMLTools.dll" to="$PLUGINDIR$\" validate="true"/>
        			<copy from="dependencies\libcurl.dll" to="$NPPDIR$\" validate="true"/>
