    Help to remove numbers with notepad
    2 Posts 2 Posters 1.2k Views 2 Watching
    • adelinefiuA Offline
      adelinefiu
      Hello, I’m a novice here, I’m trying to eliminate the numbers before and after |, I need your help
      30001sdv@|abcd34|8999
      00020dfg|abcdefgh56|0000
      2030sss|acgefty78|45
      00040xcv|jhjhjdsadj245|33
      00050|sadjjjah3|00001
      00500|blessing22|45
      The result that I need is this
      sdv@|abcd34|
      dfg|abcdefgh56|
      sss|acgefty78|
      xcv|jhjhjdsadj245|
      |sadjjjah3|
      |blessing22|
      please, thanks you
        You said “eliminate numbers before and after |”, but your example showed eliminating the numbers at the beginning or end of the line (or maybe it’s eliminating numbers at the beginning of the line, or after the final |)
        Assuming that your example, not your words, is what you want:
        • Find = ^\d+(.*\|)\d+$
        • Replace = $1
        • Search Mode = Regular Expression
